gmail Issue
Status: Closed · Asked by Osmar on · 0 views
Osmar — Question ·
Himesh Soni — Reply ·
Hello @Osmar ,
Did you checked your pabbly connect workflow history is it showing any error
If there are no errors check your sent folder in gmail.
Automation Freelancer
Email - [EMAIL][email hidden][/EMAIL]
Osmar — Reply ·
I just saw my sent emails in my gmail account and yes, the email are there… BUT these doesn’t appear in the recipient inbox.
Hey @Osmar
Kindly make a new connection for your Gmail action step and then try again.
Osmar — Reply ·
I made a new connection but it didn´t work. I still saw the emails in the "sent" folder of my gmail account but it doesn't arrive to the destination.
Osmar — Reply ·
I already tried with another gmail account and the same happened: The email is shown as "sent" in my gmail account but the it doesn't arrive to the destination. What else can i do? @Supreme
Can you create a new workflow, make a new Gmail connection and then try sending a few test emails? We are actually unable to regenerate the same issue at our end and thus find it difficult to provide a solution.
