Gmail problem
Status: Closed · Asked by AlCukovic on · 0 views
Hi, in one automation, I connected pabbly to my gmail to send an email.
When the task executes, I got the following message :
Failed: The response received from the Gmail app is shown below:
[TABLE]
[TR]
[TD]Error Code[/TD]
[TD]401[/TD]
[/TR]
[TR]
[TD]Error Message[/TD]
[TD]Request had invalid authentication credentials. Expected OAuth 2 access token, login cookie or other valid authentication credential. See https://developers.google.com/identity/sign-in/web/devconsole-project.[/TD]
[/TR]
[TR]
[TD]Error Status[/TD]
[TD]UNAUTHENTICATED"[/TD]
[/TR]
[/TABLE]
I already tried to reconnect the gmail to pabbly
Thanks for your help
Hey @AlCukovic
Can you please reconnect the Gmail action step and try again?
Hi, I set up a new connection and it worked. Thanks !
