GMB Review Reply option for multi-locations in a single workflow?
Status: Closed · Asked by matt on · 0 views
Is option used to exist but now it is no longer available and the workflows that had this setting have stopped working. Will this feature be returning?
We've added the New Review Multi Location trigger in the Updated Google My Business app. Please check and update your workflows with that.
Thank you, Naveen!
I noticed that the workflow I am using is setup the "old" way that Neeraj showed me. I am using the
3. Google Sheets : Get Row(s) (Deprecated) step.
What should this be replaced with to find a row with a random number. I.e. AX where X is a random integer.
Hey @matt
Deprecated means the new version of the same action is now available. It is recommended to use the newer version.
The old versions are not removed until 10-12 months so you can continue to use them in the meantime and it will work normally. When you have the time it's good to upgrade to the newer versions of the same endpoint.
Kindly, update your workflow with the updated Action and remove the deprecated action form there.
