Google Ads: Send Offline Conversion with GCLID not working properly
Status: Open · Asked by masteron on · 0 views
masteron — Question ·
Task History ID: IjU3NjUwNTY5MDYzMTA0Mzc1MjZmNTUzNDUxMzE1MTY1NTQzMDBmMzMi_pc
Sometimes it shows an error that it uses old API version:
"Version v17 is deprecated. Requests to this version will be blocked."
Hi @masteron,
Could you please try re-executing this task and see if that fixes your issue?
masteron — Reply ·
Hi, reexcuting doesn't help, still the same error
masteron — Reply ·
Lately error rate has increased. It's up to 30% of failed api requests to google ads
Shikha Ojha — Reply ·
I've facing the same issue. I'm missing out on data because of this.
Shreyansh Rajak — Reply ·
Hello @masteron @Shikha Ojha,
The issue related to the deprecated v17 API version has now been resolved.
You can check your workflows again — everything should work as expected.
Let us know if you face any further issues.
