google sheet to wordpress article post using openAI but second i enter title but not reflect link help
Status: Closed · Asked by Mohankumar on · 0 views
Hey @Mohankumar
You can only use "Send On Event" when setting up Google Sheets if the data is coming from a Google application or if you manually enter it. If the data is coming from a third-party application, however, you may need to choose "Auto Send On Schedule" or "Send on Schedule," which will forward the data in exactly one hour.
Additionally, make sure the data was filled up to your trigger column.
Watch the first part of the video-
