Google Sheets - Update Range Values for formulas does not seem to work
Status: Open · Asked by Davi on · 0 views
I need to populate my spreadsheet with formulas into an array in google sheets, range A1:B1
I understand that when I use text as value I need to use the symbols "" to get it to work, but since my formulas also have these same "" into them I think that might be the issue tha gives me an error 400 - Invalid JSON payload received. Unknown name "": Root element must be a message.
This is the formula that I need to use in the Update Range Values feature from google sheets (A1:B1). the formula is been duplicated
["=iferror(INDEX(INDIRECT("TXT_received!B"&"2:B1000"),SMALL(IF(INDIRECT("$A"&ROW())=INDIRECT("TXT_received!A"&"2:A1000"),ROW(INDIRECT("TXT_received!A"&"2:A1000"))-1),AS$1)),"")","=iferror(INDEX(INDIRECT("TXT_received!B"&"2:B1000"),SMALL(IF(INDIRECT("$A"&ROW())=INDIRECT("TXT_received!A"&"2:A1000"),ROW(INDIRECT("TXT_received!A"&"2:A1000"))-1),AS$1)),"")"]
Please, can someone help?
Thank you
Hi @Davi,
Please allow me some time to discuss the possibility of your use case with my team. We will get back to you with an update soon.
I had a discussion with the technical team, and they have informed me that it's not possible to pass the data/formula with double quotes in the 'Update Range Values' action step. We suggest that you try using the 'Update Row' action event or pass the formula directly into your Google Sheets spreadsheet.
