Google slide variable problem
Status: Closed · Asked by surositar on · 0 views
surositar — Question ·
During a workflow with google slide, I was unable to map the data for tags. because tags are not showing of that particular slide template.
Hey @surositar
Could you please share the name of the workflow in which you are trying the same? Also, please try refreshing the template field once and then try again.
Hey @surositar
Seems like you might not have passed the field in the Google Slide accordingly and because of that the fields are not getting populated.
So, please refer to the second part of the video to add the fields in the Google slides and then try again.
youtube.com/watch?v=9m6qC7o2Oec
