Graphy to Sender
Status: Closed · Asked by aspirecfe on · 0 views
Pramod — Question ·
Hello there,
Can you check this work flow Graphy to Sender?
I am stuck in the last step and new records are not getting added from Graphy to Sender.
Kindly check
Hey @Pramod
In the "Add Subscriber to Group" action step you need to pass the Subscriber Id in the following field with the help of "Search Subscriber".
Pramod — Reply ·
Thanks,
Search subscriber step was successful
but where and how to find the subscriber ID?
Can you please set it right?
Hey @Pramod
We have made some changes in your workflow according to the presence of the subscriber in your Sender to add to the Group.
Kindly review that and let us know if that works for you.
