Growmatik Required Fields
Status: Closed · Asked by salgeorgiou on · 0 views
Hi guys,
I have a question please for the #support team. I am trying to connect a quiz app called Marquiz with an email marketing automation called Grwomatik. My objective is when someone takes the quiz on Marquiz and provides a name and email, those two data fields to be registered on Grwomatik (to create a contact) Trouble is that when I select the Grwomatik app on Pabbly > Create Contact, it shows all fields to be required, like, name, email, surname, birthdate, city, region etc.
I contacted Grwomatik and they told me that I need to contact Pabbly support to fix that - i.e. to remove all fields from being required.
Can someone help from Pabbly? I do not see a direct support button on the website.
Thanks a million for your replies!
Hey @salgeorgiou
We have removed the required from the other fields, so kindly give it a try and let us know if that works for you.
Hey @salgeorgiouWe have removed the required from the other fields, so kindly give it a try and let us know if that works for you.
My apologies for the late reply. I tested it and it works. I can't thank you enough for your help!!
