Gsheets tp clickup
Status: Closed · Asked by patrickdoodlehog on · 0 views
Hello I created an automation rule that whenever a new row gets updated in ghseet it will be pushed to clickup as a task however its not working..any idea on this pls?
https://connect.pabbly.com/workflow/mapping/IjEwMzQ4NSI_3D
Refer to this once and check if you find a solution - https://www.pabbly.com/common-problems-with-google-sheets-integration-in-pabbly-connect/
