Hello sir, this problem is coming again and again,
Status: Open · Asked by anya mathur on · 0 views
Hello sir, this problem is coming again and again, sometimes in email and sometimes in Google Sheet, I have also sent a screenshot to it, please tell me how it will happen.
Can you please let us know what error you're getting? We are unable to understand with the screenshot you have provided to us.
google sheet row action step is showing an error symbol and "deprecated" - what does it mean and why it is displaying and how to rectify it - I also faced this issues in some of my workflow
Deprecated means the new version of the same action is now available. It is recommended to use the newer version.
The old versions are not removed until 10-12 months so you can continue to use them in the meantime and it will work normally. When you have the time it's good to upgrade to the newer versions of the same endpoint.
Deprecated means the new version of the same action is now available. It is recommended to use the newer version.The old versions are not removed until 10-12 months so you can continue to use them in the meantime and it will work normally. When you have the time it's good to upgrade to the newer versions of the same endpoint.
But sir, because of this it does not go ahead, I get mail, then it does not work.
Hey @anya mathur
Could you please share your registered email address with Pabbly and your respective workflow in which you are having trouble by creating a thread in the Private discussion?
https://forum.pabbly.com/forums/private-discussions.27/
Though meanwhile, you can try re-authenticating the Gmail action step and other deprecated actions too.
