help me create this canva + pinterest automation
Status: Open · Asked by serwar habib on · 0 views
serwar habib — Question ·
i saw a member working on this automation. i would like to do same. if pabbly team could help please.
The automation follows the following steps:
1 reads a post from my blog
2 creates the pin layout in Canva and creates design in canva according to blog post title.
3 publishes canva design on Pinterest
Hello @serwar
Please let us know the application to be used as the trigger to read the blog post and what you refer to by - creates the pin layout in Canva.
serwar habib — Reply ·
hi i was able to setup the automation using pabbly youtube videos. there is one issue I am facing. on my google sheet I don't want the work flow to only trigger after I add a new row.
i want the workflow to daily take one quote from google sheet rows. and each day take quote from the the below row than the row that It used earlier.
now I saw a solution that I could create a date column so everyday that current date row will be used to create new quote. but I want to schedule lets say 5 quotes daily.
now do I setup the workflow in such a way that it daily takes the 5 rows to create quotes. and then next day takes below 5 rows to create new quotes. please advise.
how do i schedule using google sheets on social media lets say facebook. basically I want to schedule 5 posts daily which get published at 2 hour intervals.
this is where I am struggling.
1 how do I make workflow take data from different rows each days
2 how do I make workflow take certain number of posts from sheet rows and schedule lets 5 posts daily which get published every 2 hours. thanks
You can set up the first three steps of your original workflow in this manner, which will allow you to fetch data from a new row of the Google Sheets spreadsheet at an interval of 2 hours.
https://connect.pabbly.com/workflow/share/C0NRYwRTAmEDSQhiBVoBJgEVBAAIUQNnUEkAEgYJBn4DTVQBDE0NZw9DBCYCWVMyXxYEblENBj0NGQQAAVdUJ1JIAgBdXl0nURxRKgBZCDsLVVF5BGU#
Then, you would need two other workflows: one to disable the original workflow and one to enable the original workflow.
Enable Workflow every day at 9 AM
https://connect.pabbly.com/workflow/share/XxdXZVQDVzRQGgNpBFtTdF1JBgIEXVM3XEVRQ1VaVCxbFQJXVxYIYg5CUnACWQdmA0oJYwRYAToMGFFVCF4HdAQeBwVcXwF7VRhWZVYfADNfAVd_VDU#
Disable Workflow every day at 11 PM
https://connect.pabbly.com/workflow/share/AUlWZFYBVTYFTwNpB1hTdFhMCw9XDgdjUElVR1VaAnoBTwRRBkcMZg5CAyFWDQloBE0CaAJeATpdSQoOAlQHdFdNCApUV1MpURwHNANGCToBX1Z-Vjc#
Combined, these 3 workflows will help you achieve the desired use case of posting 5 times daily from a new row of a Google Sheets spreadsheet.
youtube.com/watch?v=2wvuXIhoYRo:593
youtube.com/watch?v=Lv9Rnzoh-vY
