help me please how can i fix error code 400? i´m newbie here
Status: Closed · Asked by Oscarcd on · 0 views
Oscarcd — Question ·
what´s the detailed solution ? i´ll appreciate your help.
PabblyMember4 — Reply ·
Hey @Oscarcd
We have checked the workflow and found that you are hardcoding the values in the Google Sheets, which means whenever you are running any workflow it will enter only enter the below values in the spreadsheets.:-
Kindly do the mapping using the below video and let us know if you are still getting the same issue.
youtube.com/watch?v=j8rzX3f8dAk:249
