help me
Pramod
Hello there,
I am just starting with Pabbly connect and requirement is limited at present so my question is
1. Do Pabbly connect lifetime deal is enough? Because it has 3000 tasks only so will that be sufficient for a beginner?
2. If I go with Pabbly connect lifetime deal now in the future can I change to regular if I require more tasks?
My requirement is very simple 1. Instamojo to Mailerlite 2. Spayee to Mailerlite and a few more
So help me understand so that I can make a better decision.
Fagun Shah
1. Depends on your usage. Create a sample workflow and check how many tasks it uses per execution and then multiply it by your estimated no of executions per month. And pabbly provides up to 10000 tasks per month in LTD.
2. Yes, you can always add extra tasks as a monthly subscription on top of your LTD tasks.
I highly recommend creating a test workflow using FREE account of pabbly connect and try it out first.
Pramod
Thanks for the support.
