Help needed - Automate Client Onboarding for upcoach.com
Status: Closed · Asked by martyeducation on · 0 views
I'm looking for a way how I can automate client onboarding for upcoach.com with use of Pabbly connect.
I know that upcoach.com has that option for ConvertKit
https://help.upcoach.com/en/articles/6238772-automate-client-onboarding-with-convertkit-forms-and-sequences
I will appreciate any help.
thank you
Hi @martyeducation,
I am afraid that we currently don't support integration with upcoach.com. Kindly add a comment in the link https://pabbly.hellonext.co/b/Integration-Request for adding integration with Pabbly and also upvote it.
You can find all the available integration from this link. https://www.pabbly.com/connect/integrations/
Kunal
Hi @martyeducation,I am afraid that we currently don't support integration with upcoach.com. Kindly add a comment in the link https://pabbly.hellonext.co/b/Integration-Request for adding integration with Pabbly and also upvote it.
Kunal
Hi Kunal
Are you 100% sure it's impossible to do it ?
I don't have technical knowledge but from what I've noticed you have 'Pabbly API integration' and upcoach.com has an API feature as well.
Let me show you why I believe it can be done:
1) This is a video from your channel that shows that almost all apps with API can be connected via Pabbly:
youtube.com/watch?v=M-oU-yG-CCU
2) and this is an API documentation from upcoach.com
https://docs.upcoach.com/api-docs/quick-start
Please have a look and let me know what you think about this because if I will not be able to do it myself I can hire someone, but I need to know that it is possible first.
Thank you for your help.
Hey @martyeducation
You can further use the API by Pabbly action step to use the application in your workflow.
Moreover, you can refer to the following video tutorial on how you can use the API by the Pabbly action step.
