Help needed to Connect a form made with QuForm
Status: Closed · Asked by jbph on · 0 views
I have a form made with the QuForm Form Builder Plugin in Wordpress. There is an add-on that uses Web Hooks to connect to Zapier. From my understanding Webhooks are just simple json messages with the form data. I asked the developer of QuForm plugin and he said that the Zapier addon-on creates webhooks that:
"aren't specifically tied to Zapier, it just sends the data to the URL entered so it should work fine."
I am new to all of this automation stuff and am really struggling to find my way.... :(
Does anyone know if it's possible to connect QuForm to Pabbly Connect?
Do you have any suggestions about what I wrote above and how to connect? Would it work? If it doesn't is there an addon to connect QuForm forms to Pabbly?
Thanks in advance for any replies ?
Hey @jbph
In Pabbly Connect, you have the option to integrate webhooks by selecting the "Webhook by Pabbly" in your trigger step and adding the webhook URL to your QuForm Form Builder. This allows you to create an automation in Pabbly Connect using webhooks.
To understand how webhooks work in Pabbly Connect and how to set them up, I kindly request you to refer to the following video tutorial:
youtube.com/watch?v=FRkl5R7-Ls0
Please let me know if you facing any issues.
