Help with Http API on Pabbly Connect pls!
Status: Open · Asked by lma on · 0 views
lma — Question ·
Hi guys,
Sorry for my ignorance. How can I use the "file" field on a Http API on Pabbly but loading the file from a url instead of locally? I need this for an automation:
Thank you in advance!
Neeraj Agarwal — Reply ·
Does your API support sending the file to them on POST directly through the URL?
If yes, you just include the whole file URL path of the file available online.
file https://pabbly.com/someimage.gif
This will only work if the API supports capturing files from the public file URL.
