Help with Monday.com automation
Status: Closed · Asked by StephenG on · 0 views
Hi @StephenG,
Could you please share the Workflow URL in which you are facing this issue?
Please allow us some time to look into this. We will get back to you shortly.
StephenG — Reply ·
Thx!
Within the "Monday: Create item" action step, the custom fields "Email (Label)" and "Email (Email Address)" are established for capturing email addresses. It is essential to input an email address in both of these fields; otherwise, an error will occur.
You may check the same in the following short recorded video -
https://www.screenpresso.com/=w9f5c
StephenG — Reply ·
Great thanks for the help!!
