Help with Monday.com automation
Status: Closed · Asked by StephenG on · 0 views
I made a video about issues I’m having with a Monday.com automation.
https://www.loom.com/share/02c9ed1eb10a453eadeeeda8922af5da
Would appreciate some help!
Hi @StephenG,
Could you please share the Workflow URL in which you are facing this issue?
Please allow us some time to look into this. We will get back to you shortly.
Thx!
Within the "Monday: Create item" action step, the custom fields "Email (Label)" and "Email (Email Address)" are established for capturing email addresses. It is essential to input an email address in both of these fields; otherwise, an error will occur.
You may check the same in the following short recorded video -
Great thanks for the help!!
