Help
Status: Closed · Asked by Brijesh Parikh on · 0 views
Brijesh Parikh — Question ·
Can I Bring my webinar registrant to a google sheet and using the webhook scheduled feature can send reminder messages using SMS Horizons API?
Brijesh Parikh — Reply ·
Webinarjam
Fagun Shah — Reply ·
Webinarjam
Pabbly don't have triggers for Webinarjam yet,
BUT if you register people in webinarjam from pabbly connect then for each registration you will get their unique URL to accessthe webinar.
Which you can add to google sheet after that.
Fagun Shah
- Automation Freelancer
Ok so in that case I also bring data to my autoresponder using native integration of webinarjam, from my autoresponder to google sheet and then using webhook schedule feature send reminder sms at a scheduled time, can I do that?
Yes, you can do that.
You can use a scheduler or delay module (as per your requirement) to achieve this.
Fagun Shah
Thank you
