Here's quick guide to Pabbly Connect
Status: Closed · Asked by panagiotis on · 0 views
how to authenticate my Gmail account to pabbly connect?
Hey @panagiotis
You can refer to the following video tutorial on how you can authenticate your Gmail action step.
THANKS
I THING I CONECTED
BUT I HAVE ERROR MESAGES WHEN I SENT THE TEST EMAIL AND DIDN WORK.
IT NEADS TO TYPE ONLY HTML CONTENTS IN THE SUBJECT FIELD?
i have this one
Hey @panagiotis
Please make a new connection and try again.
L DO IT A LOT OF TIMES
Hey @panagiotis
By any chance, have you been invoking this from a GCE VM? If so, you might want to:
1 Stop the VM
2 Go to the GCE VM instances in the cloud console
3 Click edit on the machine
4 Go to scopes
5 Edit the scopes as desired (preferably adding the scope just to a particular API or if you are OK with it - to all APIs, depending on context and risk)
6 Restart the machine and make the API call again
