Hexometer Integration Does Not Have Webhook URL
Status: Closed · Asked by Henry Hoe on · 0 views
decisivemarketer — Question ·
Please check and fix.
Hey @decisivemarketer
The Hexometer trigger event is available as a post-webhook type trigger event on the platform where you only need to connect the application with the help of an API key.
Also, if your Hexometer account supports the webhook then you can use the "Webhook By Pabbly" trigger event to catch the webhook response from the Hexometer.
