HighLevel Intergration - Phone Number No Longer Required
Status: Closed · Asked by Daniel Greenhow on · 0 views
Dan G — Question ·
Using the "Create Contact" feature with the HighLevel integration Pabbly forces you to enter a phone number for the new contact. I know this is no longer a required field by HighLevel.
Can I request we stop making the phone number a required field for the Create Contact task?
This is causing issues for a campaign I am running where I do not request a contact's phone number as I'm unable to add them using Pabbly and so stuck with Zapier.
Thanks in advance.
Hey @Dan G
As per the HighLevel API documentation, a phone number must be a required field. So we cannot make it an optional field as you're requesting about.
As a workaround, you can use {{skip}} in the phone field as shown below -
Dan G — Reply ·
Hey @Dan G
Ah ok, that will work for me, thank you!
