How can easy move Workflow to other position in classic mode?
Status: Open · Asked by Ton Won on · 0 views
Like drag & drop the workflow after the other steps.
Pls advise!
Hello @gpro,
Currently, Pabbly Connect does not support drag-and-drop functionality in the Classic Builder. In this mode, steps cannot be moved directly—you can only copy and paste them if needed.
If you prefer a more flexible and improved UI, we recommend using the New Workflow Builder, where the interface is more user-friendly, though drag-and-drop is still not supported.
