How Can Fetch Orders from Amazon.in and Send it to Zoho books
Status: Open · Asked by CARKEY INDIA on · 0 views
Dear Pabbly Any Possiblity to Send Amazon Orders to Zoho book via Pabbly
Any body help me to configure workflow
I just want Amazon Order to sent to Zoho book for Accounting purpose, As already So many Flatforms Fetchs Order from Amazon like unicommerce ,OMSGuru etc.
So If they can Fetch orders from amazon ,Pabbly Should able to do this
I just want Invoice number & Order ID from Amazon
Hello @Sreejith,
Thank you for reaching out and sharing the details. Upon checking, it seems there might be some input error. Kindly share a screenshot or a short screencast showing how you have set up the connection with Amazon so that we can guide you accordingly.
I currently reciving Order data from Amazon but it fetchs only last New order ,Also Invoice Number is not fetching
Hi Sreejith,
Thanks for sharing the screencast!
Just to clarify, based on our research, Amazon's API does not provide the invoice number, no matter who ships the order. So, getting the invoice ID directly isn’t possible right now.
Also, the trigger you’ve set up is designed to fetch only the latest new order based on the selected status — so it’s working as expected.
Then How Unicommerce(unicommerce.com) & OMSGURU(omsguru.com) Fetchs Invoice Number + Return Orders etc Earlier I was using there Flatform So I know about it ,Amazon API 100% allow ,Only the Customer Mobile number is hidden Rest all data can be fetch from Amazon via API
Thank you for reaching out. The Amazon Seller Central integration you are trying to use is currently in beta, and at this time, Pabbly does not have permission to access PII details, including customer mobile numbers.
If you would like to improve this functionality and require fields like the Invoice ID, you may submit a specific request on our roadmap. Our team will review it and consider implementing it if feasible.
