HOW CAN I CONNECT A SHOPIFY STORE WITH PABLY CONNECT?
Status: Open · Asked by man121010 on · 0 views
man121010 — Question ·
Hi Pabbly Support,
I need help connecting my Shopify store to Pabbly Connect. Can you provide a step-by-step guide on how to set up the integration? Specifically:
• How to authorize and link Shopify with Pabbly Connect
• Any required API keys or app installations
• How to set up triggers/Webhooks (if needed)
• Required permissions in Shopify
Please share exact steps and any common pitfalls.
Thanks.
Hey @man121010,
You can follow the tutorial below to learn how to add webhooks in Shopify, which will help you complete the connection process:
youtube.com/watch v=OFFLJs928oM:220
For connecting Shopify with the Action event, please refer to this forum guide:
https://forum.pabbly.com/threads/how-to-find-client-id-client-secret-and-scopes-in-shopify.34226/
These resources will help you set up both the webhook trigger and the action connection properly.
