How can I connect SaleForce to Pabbly not using AP16 Instance?
IQIGlobal
I wanted to connect SaleForce to ActiveCampaign using Pabbly, but kinda hard to link it as pabbly need to use AP16 Instance but for our SaleForce account we are using JPN17?
Where can we find the Instance URL?
PabblyMember3
You can get your instance from Setup->Left Sidebar->Company Profile->Company Information then search for Instance it look like AP16 , AP12 etc. If your instance is AP16 then instance url will be https://ap16.salesforce.com
If your instance is JPN17 then, the instance url should be https://jpn17.salesforce.com, try this URL in Pabbly Connect Salesforce app connection once. Hope that works.
