How can run Pabbly flow via URL
tisaigon
In 3rd tool (i used Podio), i want to call Pabbly flow and run this flow via URL ?Is possible?
Example: in Robomotion i can do this.
Thank you
You may refer to the following video on the Data Forwarder action step, on how you can use it.
Please give it a try, I hope this might help you out.
