How can run Pabbly flow via URL
Status: Closed · Asked by ti saigon on · 0 views
In 3rd tool (i used Podio), i want to call Pabbly flow and run this flow via URL ?Is possible?
Example: in Robomotion i can do this.
Thank you
Hey @tisaigon
You can use the "Data Forwarder" action step to move the data with your desired API call.
Hi thanks @Supreme , do you have video about it? Thanks
You may refer to the following video on the Data Forwarder action step, on how you can use it.
Please give it a try, I hope this might help you out.
