How can we fix this problem? Could not coerce value [] to String
Status: Open · Asked by Emmanuelle on · 0 views
How can we fix this problem? Could not coerce value [] to String, its in an automatisation for update product
Hello @Emmanuelle,
Could you please provide more details about the issue you are facing and specify which step of your workflow is affected Additionally, kindly confirm if you are referring to or encountering this issue in the workflow mentioned below.
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZlMDYzZTA0M2M1MjY0NTUzMDUxM2Ei_pc
