How do i connect meta leads to crm ?
Status: Closed ยท Asked by Chhotu maharaj Cinema boxoffice on ยท 0 views
Chhotu maharaj Cinema boxoffice โ€” Question ยท
I am trying to connect my meta lead form to CRM but campaign name is not coming when i generate webhook response nor campaign id is coming.
Pabbly Support โ€” Reply ยท
Hi Chhotu Maharaj,
Thank you for contacting Pabbly Support.
We checked your workflow (Higher Intent Api) and can confirm that Meta is now returning all campaign details in your trigger response!
You can find them under the following labels in your Response Received data:
  • Campaign Name: res3 campaign_name (Tier 2 and 3 Cities)
  • Campaign ID: res3 campaign_id (120251466378340017)
  • Adset Name: res3 adset_name
  • Ad Name: res3 ad_name
Next Steps: Simply open your CRM Action Step (below the trigger in Pabbly Connect) and map res3 campaign_name and res3 campaign_id into the respective CRM fields so they get pushed automatically with every lead.
Feel free to reply if you need any assistance with mapping!
Hrishabh
๐ŸŒ Pabbly.com
๐Ÿ‘‰ Rate your support
