How do I create a multi-step workflow in Pabbly Connect?
Status: Closed · Asked by Suheb on · 0 views
Suheb — Question ·
How can I set up an automation that performs multiple actions in a row — like sending an email, updating a spreadsheet, and sending a Slack message — all in one workflow?
Hello @Suheb,
You can set up a multi-step workflow as shown in the attached image. We’ve also included a tutorial that covers a similar, though not exactly the same, use case, which should help guide you through the setup.
youtube.com/watch v=M8nDCh_iZdk
