How do i enable legacy Meta AI agent onto pabbly?
Status: Closed ยท Asked by CAIROFLO Omni Marketing Fahmy on ยท 0 views
CAIROFLO Omni Marketing Fahmy โ€” Question ยท
Pabbly Support โ€” Reply ยท
Hi Ashraf,
Thank you for reaching out!
To set up an AI agent or integrate Meta services with Pabbly:
  1. Pabbly Connect: You can build AI agent workflows using OpenAI, Meta/Facebook/Instagram, or Pabbly's internal AI Assistant module directly inside your Pabbly Connect dashboard.
  2. Pabbly Chatflow: If you are referring to WhatsApp AI assistants powered by Meta Cloud API, you can enable AI agents under the AI Assistant / Chatbot Builder section within Pabbly Chatflow.
Could you please clarify which specific legacy feature or integration step you are trying to enable (e.g., Meta WhatsApp Cloud API agent, OpenAI assistant via Meta webhook, or Pabbly Chatflow AI)?
Once you share a few more details, we'll be happy to guide you.
Hrishabh
๐ŸŒ Pabbly.com
๐Ÿ‘‰ Rate your support
CAIROFLO Omni Marketing Fahmy โ€” Reply ยท
I meant meta ai agent. It was deployed on an another number using meta business as WhatsApp API manager not Pabbly. It is an agent inside WhatsApp. That is added automatically In WhatsApp business app
Ashraf Fahmy
Founder & Marketing Executive | CAIROFLO 360 Marketing
Partner & CMO | Retal Ice Cream LLC.
Email:  [email hidden]
Contact Number: +20 1122504767
Website: cairoflo.com
CONNECT WITH ME:
LinkedIn Instagram YouTube Retal Ice Cream
 Book a Free Consultation
On 28 Jul 2026, at 7:46โ€ฏAM, Pabbly Support <support@pabbly.com> wrote:
๏ปฟ
Hi Ashraf,
Hrishabh
๐ŸŒ Pabbly.com
Hi Ashraf,
Thank you for clarifying!
The built-in Meta AI agent you are referring to is a feature native to the WhatsApp Business mobile app managed directly by Meta.
When you connect a phone number to Pabbly (via the WhatsApp Business Cloud API), the number operates on Meta's official Cloud API infrastructure rather than the mobile app interface. Because of this:
  1. API Limitation: Meta does not expose its native mobile app AI agent through the WhatsApp Cloud API for third-party platforms like Pabbly.
  2. Alternative Solution: To use AI automation on a Cloud API number connected to Pabbly, you can connect an AI agent (such as OpenAI / ChatGPT) directly inside Pabbly Chatflow.
If you specifically need to keep using the native Meta AI assistant inside the mobile app on that phone number, the number must remain active in the WhatsApp Business mobile app as well.
Please let us know if you have any questions or if you'd like guidance on setting up an OpenAI-powered AI agent via Pabbly!
Hrishabh
๐ŸŒ Pabbly.com
