How do I keep a Chat GPT thread going?
Status: Closed · Asked by William Mingione on · 0 views
billymingione — Question ·
I would like to be able to have a normal conversation using chatGPT through Pabbly but how can I get to to respond using a previous prompts input?
Meaning if I give it a prompt saying:
I'm going to send you two messages, the first message is going to be how I would like you to....... The second message is going to be a CSV file which I would like you to use to reference information.
The second message (tied to the first prompt) is a CSV file.
How do I do this Pabbly with the chats connected in the same thread? Is there some kind of conversation code or ID that needs to be input after the first response?
Hey @billymingione
I am not sure that the use case that you are trying to build is possible.
billymingione — Reply ·
So there is no way to actually have a conversation with chat GPT API through Pabbly at this point?
I just want to be able to have a chat with chatGPT like I normally would through the website (but on Pabbly)
Currently, there is no possibility of processing the chat with ChatGPT.
