How do we check (filter) if a field is empty or not?
Status: Closed · Asked by jonbstrong on · 0 views
I have an automation where I want to send a slack message if a form field contains some data.
When it comes to conditionality, Pabbly has a couple of options
I assumed that that "is exist" would only filter the responses that are not empty but this is not happening.
Is there another way of filtering out empty responses?
I assumed that that "is exist" would only filter the responses that are not empty but this is not happening.Is there another way of filtering out empty responses
I think this can be achieved in multiple ways, try the simplest first. Select filter Does Not Equal to and leave Value field empty and try -
