How does Airtable to OneNote work
Status: Closed · Asked by SamStam on · 0 views
I'm interested in Airtable to OneNote.
Trigger is Airtable new record.
Action is OneNote : Append Html Note.
I've checked your documentation. It's unclear exactly where in OneNote the Airtable record will be placed. I need it to go to the bottom of a specific page. How do I do this?
Hey @SamStam
As we can see from your workflow, you haven't connected your trigger and action step to syncing the data.
So, kindly first make a connection to the steps and then try again.
(Watch the first part of the video on how you can get the trigger response from Airtable)
youtube.com/watch?v=SdANytlWdWc
And refer to the following screenshot on how you can use the "OneNote: Append Html Note" action step.
