How rename an automation?
Status: Open · Asked by Klaziena, Slim Slank Coach on · 0 views
Klaziena — Question ·
I have made an automation but how can I rename it?
Kind regards,
Klaziena Waerts
Hello @Klaziena
You can rename a workflow following the below steps:
1. Open the workflow to be renamed.
2. Click on the three dit just Beside the workflow name and choose the Rename option, refer to the below image for more info.
3. A popup will appear, enter the name and click on the Update button, refer to the below image for more info.
Klaziena — Reply ·
I see nowhere 3 dotts
Resham — Reply ·
Sorry, for the last email!
Follow this process:
1. Go to automation section> choose the automation for which you wish to edit the automation name > click on edit
2.
