How to add a product to a lead with Zoho CRM
inel
I was looking for an option to add the products we have in Zoho CRM to a lead. Unfortunately, I didn't find a way to do it.
  • I only found these fields related to leads:
    I share only the fields that allow adding:
    In products, I can't find a task to add a product to a lead:
    Automation allows me to create the prospect successfully:
    My goal is to add a product to the prospect from the same automation:
    The result I need the automation to perform:
How could I do that automation?
I would like you to guide me to solve the problem, I may not be doing it correctly
Good day
ArshilAhmad
Moderator
Hi @inel,
It seems like you are looking to create a sales order. Please try using the 'Create Sales Order' action event to achieve your use case.
inel
Hi ArchilAhmad,
I appreciate the immediate response. However, the "Sales Order" event is another Zoho CRM module that is not related to leads:
The automation we need is in the "Leads" - "Prospects" module.
When a record is created in the automation, it automatically adds a specific product to the lead.
I am grateful for your help. If there is a way to do that procedure, I would be happy if you could guide me.
Have a great day.
inel
Si es un campo manual que hemos creado, ya que no hay ese campo, y necesitamos agregar un producto al prospecto desde la misma automatización.
Su ayuda por favor.
ArshilAhmad
Moderator
Please try using the 'Insert/Update Record' action event. It seems that the 'Nombre De Producto' field is being fetched now.
inel
Good morning, I appreciate your support, but as I mentioned, I created the "product name" field manually, but that field does not exist in Insert/Update.
We want the product name to appear automatically in the prospectus, please help.
ArshilAhmad
Moderator
Do you want the fields marked in yellow or the product name marked in red to appear in action step?
