How to automate whatsapp api conversation flow?
Status: Closed · Asked by Smart Accountants on · 0 views
Can we automate the conversation flow of the WhatsApp of API ? If not, how to converse with the replied messages.
Right now, WhatsApp Cloud API is meant for sending notifications only. Its not meant for doing conversations.
Further you can collect the response in a Google Sheet as explained in below tutorial -
Hello! Is it possible to do both with 360Dialog. To automate and receive messages at the same time.
If there are any alternatives, Specify them
You can consider using 360Dialog with any third party apps. Refer below screenshot for reference -
