How to connect Claude to Pabbly using MCP?
Status: Closed ยท Asked by Fery Irawan on ยท 0 views
Fery Irawan โ€” Question ยท
Hi
How to connect Claude to Pabbly using MCP? If already connect , so I can connect to other li joggai and pcloud. Please guide me step by step. Thanks
Pabbly Support โ€” Reply ยท
Hello Fery,
Thank you for reaching out.
To connect Claude with Pabbly Connect using MCP (Model Context Protocol), please refer to the documentation and video tutorial below. They provide a step-by-step guide for setting up the connection and using MCP with Pabbly Connect.
Documentation: https://forum.pabbly.com/threads/pabbly-connect-mcp-server-beta.28381/
Video Tutorial: https://youtu.be/EKljtF6LSQs?si=VbfF5CswkiHGCgw9
Once you've successfully connected Claude using MCP, you can similarly connect and use other MCP-compatible services, such as JoggAI, pCloud, and others, provided they support the MCP standard.
If you face any issues while following the guide, please let us know where you're getting stuck, and we'll be happy to assist you further.
Anushka Sahu
๐ŸŒ Pabbly.com
Fery Irawan โ€” Reply ยท
When direct integration will available ? In video tutorial that you share , using google chat first . I want direct connect
On Wed, 15 Jul 2026 at 12.20 Pabbly Support <support@pabbly.com> wrote:
Hello Fery,
Anushka Sahu
๐ŸŒ Pabbly.com
Hello Fery,
At the moment, MCP is supported only in the Action steps of Pabbly Connect and is not available as a Trigger.
We recommend following the documentation we shared earlier, as it explains the current setup and supported use cases in detail.
Also, could you please let us know what you mean by "direct integration" and what your specific use case is? Understanding your requirement will help us suggest the best possible approach or an alternative solution.
If you have any questions while following the guide, please let us know. We'll be happy to assist you.
Anushka Sahu
๐ŸŒ Pabbly.com
We hope you're doing well.
We're just following up on our previous email to check if you had a chance to review the information we shared.
If you have any questions or need any further assistance, please feel free to reply to this email. We'll be happy to help.
We look forward to hearing from you.
Anushka Sahu
๐ŸŒ Pabbly.com
Actually I still confused how to using MCP pabbly to claude. Even there is tutorial already. But it is OK ,my best friend  Claude will help me.
Anushka Sahu
๐ŸŒ Pabbly.com
Thank you for your update.
No worries at all! We understand that setting up the Pabbly MCP with Claude can be a bit confusing initially.
If Claude's guidance helps you get everything configured successfully, that's great. However, if you still face any difficulties or get stuck at any step, please feel free to reach out to us. We'll be happy to assist you and guide you through the setup.
We wish you the very best with your implementation, and we're here if you need any further assistance.
Anushka Sahu
๐ŸŒ Pabbly.com
Thanks for your support.
Anushka Sahu
๐ŸŒ Pabbly.com
