How To Connect MailerCloud to Convertri?
Status: Closed · Asked by ChristianL on · 0 views
How can I connect leads from Convertri to a list in Mailercloud?
Hey @ChristianL
As we can check from your Convertri webhook option, we couldn't find any option to get the leads from it. So, if you are trying to retrieve the purchase from Convertri, then you can use the "Convertri: New Purchase" trigger event and pass it on "Mailercloud: Add Contact to List" action step.
Please refer to the following screenshot for the same.
You may following the given documents and try again.
https://help.convertri.com/article/392-how-to-use-webhooks
