How to Connect Memberpress?
Status: Closed · Asked by otherlife on · 0 views
I see that Memberpress is one of the supported apps, yet when I try to connect it within my workflow, it's not there. Please advise!
Nevermind. Apparently, Memberpress can't be used within a workflow. It can only be used as a trigger. This is quite disappointing. lol Is there any way other than API to add it within a workflow?
Hey @otherlife
In that, you can use API by Pabbly action step where you can design the API by yourself. You check for the API documentation from the Memberpress team.
You can also refer to our tutorial video on "API by Pabbly". Kindly try this at your end and let us know how it works for you.
youtube.com/watch?v=M-oU-yG-CCU
Further, If you want to request for building up new integrations, please send us the request here and upvote it -
Thank you for your reply! I was able to get the API to work and now it's running beautifully. Thank you!
