How to Connect MongoDB with Pabbly Connect
Table of Contents​
  1. Overview
  2. Prerequisites
  3. Security Requirement: Whitelisting Pabbly Integration Server
  4. Step 1: Whitelist IP Address in MongoDB Atlas
  5. Step 2: Retrieve MongoDB Connection String
  6. Step 3: Establish MongoDB Connection in Pabbly Connect
  7. Step 4: Configure MongoDB Action
  8. Step 5: Test and Save the Workflow
  9. Common Errors and Troubleshooting
  10. Final Verification Checklist
1. Overview​
The MongoDB integration in Pabbly Connect enables users to automate database operations such as inserting, updating, retrieving, and deleting records from MongoDB Atlas through workflow-based automation.
To ensure secure and uninterrupted communication between Pabbly Connect and MongoDB Atlas, proper IP whitelisting and authentication are mandatory.
2. Prerequisites​
Before proceeding, ensure the following requirements are met:
  • An active MongoDB Atlas account
  • A running MongoDB cluster
  • A MongoDB database user with appropriate permissions
  • Access to Pabbly Connect
3. Security Requirement: Whitelist Pabbly Integration Server​
MongoDB Atlas enforces IP-based access control. To allow Pabbly Connect to communicate with your cluster, the Pabbly Integration Server IP must be whitelisted.
Pabbly Integration Server IP​
Server IP: 157.180.81.74
⚠️ Important: Failure to whitelist this IP will result in connection and authentication failures.
4. Step 1: Whitelist IP Address in MongoDB Atlas​
4.1 Sign in to MongoDB Atlas​
📷 Screenshot: MongoDB Atlas Dashboard
4.2 Select Your Project​
  • Choose the project that contains your MongoDB cluster
📷 Screenshot: Project Selection
4.3 Open Network Access Settings​
  • Navigate to Network Access from the left sidebar
  • Open the IP Access List section
📷 Screenshot: IP Access List
4.4 Add Pabbly Integration Server IP​
  1. Click Add IP Address
  2. Enter the IP address: 157.180.81.74
  3. (Optional) Add a description
  4. Click Confirm
📷 Screenshot: Add IP Address
Expected Outcome:
The IP address appears with an Active status.
5. Step 2: Retrieve MongoDB Connection String​
5.1 Navigate to Clusters​
  • Go to Database → Clusters
  • Click Connect on the target cluster
📷 Screenshot: Cluster Overview
5.2 Select Connection Method​
  • Choose Connect your application
📷 Screenshot: Connection Options
5.3 Copy Connection String​
  • Select the appropriate driver
  • Copy the provided connection string
Example: mongodb+srv://<username>:<password>@cluster0.mongodb.net/<database>
📷 Screenshot: Connection String
ℹ️ Note:
Replace <username>, <password>, and <database> with your actual MongoDB credentials.
6. Step 3: Establish MongoDB Connection in Pabbly Connect​
6.1 Access Pabbly Connect​
  • Log in to Pabbly Connect
  • Create a new workflow or open an existing one
6.2 Add MongoDB Action​
  • Click Add Action
  • Select MongoDB
  • Choose the required action/event
6.3 Create a New Connection​
  • Click Add New Connection
  • Paste the MongoDB connection string
  • Click Connect
Expected Outcome:
The connection status displays Connected.
7. Step 4: Configure MongoDB Action​
  • Select the database name
  • Select the collection name
  • Map all required input fields according to the selected MongoDB action
ℹ️ Note: Ensure all mandatory fields are mapped correctly to avoid execution failures.
8. Step 5: Test and Save the Workflow​
8.1 Test the Action​
  • Click Save & Send Test Request
  • Review the response returned by MongoDB
8.2 Save and Enable Workflow​
  • Click Save
  • Enable the workflow for execution
Expected Outcome: The workflow executes successfully without validation or runtime errors.
9. Common Errors and Troubleshooting​
Connection Failed​
  • Verify IP address is whitelisted
  • Check MongoDB username and password
  • Confirm database name in the connection string
Authentication Failed​
  • Ensure MongoDB user permissions are correctly assigned
  • Verify read/write access for the database
Timeout or Network Error​
  • Allow a few seconds after IP whitelisting
  • Retry the connection
10. Final Verification Checklist​
✔ MongoDB Atlas account active
✔ Pabbly Integration Server IP whitelisted
✔ MongoDB user created with correct permissions
✔ Connection string verified
✔ MongoDB connected in Pabbly Connect
✔ Action tested successfully
✔ Workflow saved and enabled
Completion Status​
You have successfully configured MongoDB with Pabbly Connect. Your workflows are now ready to perform secure and automated database operations.
