How to connect Oppyo.
Status: Open · Asked by Shahidul Islam Pranto on · 0 views
I am little bit confused how to connect Oppyo app with Pabbly. The app says me to provide Token.
Hi @shahidul islam pranto,
Currently, we don't have a direct integration with the Oppyo application. It seems like you are trying to use the API by Pabbly module to integrate with this application. I suggest you get in touch with Oppyo's support team to understand what token they are asking for, as they are much better equipped to provide you with this information.
