How to connect pabbly with wati
Status: Closed · Asked by ravidigitechniks on · 0 views
ravidigitechniks — Question ·
Can you please explain me this issue
Hey @ravidigitechniks
As these are key-value pairs, you will have to map the correct fields with the data you want for your template. For example, you want the name to be 'ravi', so your input should be like -
{ "name": "ravi", "color": "blue" }
Refer to this video for more instructions -
youtube.com/watch?v=iw_gPmWpejM:946
ravidigitechniks — Reply ·
Hi
How we can send reminder message from wati Automatically to the registrants.
You can surely do that with the help of Pabbly Connect. Kindly refer to this video from 22:50 -
youtube.com/watch?v=rzvp9VEKzaM:1371
Can you connect with me I have tried it but not working
Kindly clarify a bit more on what issues are you facing while setting up the connection. It would be very convenient if you could make a video about you issue so that we can look into it and assist you accordingly.
