How to connect to Drupal
Status: Open · Asked by jsidigital on · 0 views
jsidigital — Question ·
Need to connect to Drupal and Drupal Commerce.
When drupal commerce sale completes, send message via whatsapp.
Or select drupal article and send link via whatsapp, etc.
In the first step of workflows, it shows triggers. I see wordpress, but not drupal.
What has to be done in order to add Drupal to that list of connections?
Thank you.
Hi @jsidigital,
Currently, we don't have a direct integration with Drupal. If you want this application to be added to Pabbly Connect, you can submit your request on our dedicated platform: https://pabbly.featureos.app/b/Integration-Request
Our integrations team will look into your request and, if possible, add the desired application to Pabbly Connect.
In the meantime, if Drupal supports Webhooks, you can try using Webhook by Pabbly to achieve your use case.
youtube.com/watch?v=wmeg-Ixpppw
