how to connect to systeme.io webinar and get webinar broadcast link direct and send notification
Status: Open · Asked by richmike on · 0 views
how to connect to systeme.io webinar and get webinar broadcast link direct and send notification maybe 1 day, 15minit,
since webinar room for systeme.iO is no same every times? i wisih to use pabbly for it
Hi @richmike,
To achieve this use case, you can setup your workflow in the following manner:
https://connect.pabbly.com/workflow/share/WBAFNwdQBGdUHgljAVIGIQ4aBQFXDVZqBh8AElVaUChTCQBrDUwLYQFNVXdTFAhpXxYHbVUJAD0AFFdTVAJWJVNKVHhVVlAqA04CMVAZWmlYBgUtB2Y#
You can replace Gmail action step with any application of your choice to send the notifications.
did not understand it, how the webinar link to be send as well??
the above is google sheet, i wan systeme.io webinar, auto send the webinar link using whatsapp
I am afraid, sending the Webinar link in the message is currently not possible.
