How to connect to Thinkific
Status: Closed · Asked by serenitydojo on · 0 views
serenitydojo — Question ·
Im trying to connect to Thinkific but I get stuck on a page saying that the app is not verified, where the "Accept & Install" button is disabled. How do you get around this?
Hey @serenitydojo
Kindly refer to the second part of the video tutorial on how you can connect your Thinkific account to the platform.
youtube.com/watch?v=qQhTRFKMjQk
serenitydojo — Reply ·
Hi, this doesn't work for me - when I connect to Thinkific, I get the following window, but with no way to click on "Accept and Install".
The Thinkific support folk say that there is no integration with Pabbly Connect, so it's a little confusing...
We have contacted the Thinkific team regarding the same and will notify you once we have an update for you.
Jreynolds — Reply ·
Following
Hey @Jreynolds
It may take some time while our team is in communication with their team, but we will let you know as soon as we get any updates.
aatmn.parmar — Reply ·
Hey we are still having that probem connecting to thinkific - the greyed out accept and install button as mentioned by serenitydojo is what we are facing too
Has this connection yet not been corrected since November?
Hey @aatmn.parmar
The Thinkific team has updated its Authentication method since then the integration is not working for new connections.
Further, we have contacted them regarding the same, and once they provide the proper solution to the concern, we will also update the integration for new connections as well.
Dear Supreme,
Is it possible to get a timeline for the same?
It'll take some time. We are unable to provide you with an ETA since extensive testing and compatibility testing must be done before deploying any new update in an existing integration. You will be contacted as soon as we deploy the action event, as stated before.
