How to create a two way sync connection between shopify and woocommerce products?
Status: Closed · Asked by Talal on · 0 views
Talal — Question ·
I am trying to connect shopify and woocommerce through pabbly. I made the connection and the workflow. The workflow only works when a new product is created. But I want to import all existing shopify products to woocommerce and sync them, two way. So whenever any product is edited or updated on any platform, it should sync it on both shopify and woocommerce platforms. Thank you.
Please help!
It'd be great, if someone can explain the workflow :)
