How to create a two way sync connection between shopify and woocommerce products?
Talal
I am trying to connect shopify and woocommerce through pabbly. I made the connection and the workflow. The workflow only works when a new product is created. But I want to import all existing shopify products to woocommerce and sync them, two way. So whenever any product is edited or updated on any platform, it should sync it on both shopify and woocommerce platforms. Thank you.
Please help!
It'd be great, if someone can explain the workflow :)
Supreme
Hey @Talal
You can synchronize your Shopify products and transfer them all to WooCommerce at once. Please refer to the accompanying screenshot where we have outlined the steps you can follow and try on your end.
